Re: 3.0 motor and Faulty starts?
#14863
Hello all, I have also purchased a 3.0 as well as a 3.8 and have not experienced any of the above simptoms. A friend of mine also purchased a Bit Char-g with a 3.0 and i noticed that his gears were fitted a little different that mine. Just wondering if maybe some of you are fitting your gears a little tight and causing binding. With the lack of torque from thehigher rpm motor, you cant get the gears to spin without a little help. Might check it out…
