Re: 3.0 motor and Faulty starts?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › 3.0 motor and Faulty starts? › Re: 3.0 motor and Faulty starts?
my 3.0 works ok in some cars and has probs in others – i cannot work out why! i have fiddled with the way it fits in, and the best solution seems to be to use a cable to tie the motor in position, as you can be more accurate than with the steel motor cover.
i tried bits of paper or card in different spots around the motor (when using the motor cover) but my problem was that the motor needed to be seated LOWER than the steel cover would allow for to avoid the gears binding.
i now have it working ok strapped in tomy 2.4v booster – i just need to work out a neat and portable charging solution!
