Re: 4 channel booster controller
#14782
I have 5 different non-Tomy variants now, and they all use different Rx boards, but all can be rewired to accept signals from normal Tomy Tx. I’d personally stay away from modifying the oem controllers to send the correct signals If you’re going to use Tomy controllers primarily- the process involves mounting subminiature pressre switches where the buttons normally contact and bypassing the existing contacts. If you have the patience, a better solution would be to cut the traces and either rewire or use a trace pen to reverse the wiring.
As it is, I find both the 4-band and the stock tomy Tx are better than most OEM’s.
-dan
