Re: A-40
#51638
oldtamiyaphile
I’d skip the wall charger idea, there are no power points at the park. I use a SJ Swallow peak charger now, it’s around $120, and runs of a 12v car battery, much more useful at the park.
If you can’t spend that much any wall charger with ~300mah output and 6v will do the trick, you’ll have to fashion your own charging plugs (change them all to Deans micro plugs, which I use on all my micro cars/boats/planes).
You could add bigger batteries but the extra weight will adversly affect performance. The answer for doubling flight time is lipo’s, but that requires the charger mentioned at the top of this post.
