Re: Batt and motor limits
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Batt and motor limits › Re: Batt and motor limits
January 20, 2003 at 1:18 am
#42997
Most likely designed differently ( I havent checked yet) The 1.0 would take more voltage because it probably has a higher resistance. A 3.8 would have less windings of thicker wire inside and would therefore have less tolerance to having more current shoved down its throat by increasing the voltage. I intend to test a couple of motors to destruction (and rewind them??), but I want to get a proper lab power supply first so I can properly record the results. Give me a couple of days…watch this space.
uA :question::question::question:
