Re: Bit Char-G vs. Bit Racer
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Bit Char-G vs. Bit Racer › Re: Bit Char-G vs. Bit Racer
It’s well worth buying the set pictured above if you can get it cheap. You get a spare battery (worth it already) and a set of medium (quite hard actually) tires which fit fine on a Char G.
Apparently you can use the motor cover – why? I don’t know. If you ever wear out your Char G one I suppose it could come in handy :smiley1:
The axle you get can supposedly fit with a lot of fiddling. You could use the wheels – again, why? Better to get the proper Char G set. The gear’s no use. The stickers are compatible :smiley1: and you can use that stupid plastic thing for a wheely bar if you’re keen.
Short story, get it for the battery and if you’d like some different tires to experiment with.
The next set up, the one with the controller is the one you want. With that one you get the added bonus of a yellow 2.0? motor. Well worth it.
Nick.
