Re: can someone explain batteries to me?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › can someone explain batteries to me? › Re: can someone explain batteries to me?
Hey ADS, I got some questions. I’ve been reading about these a little. I was steering clear of them because I was finding info about it being bad to discharge the batts all the way. They come at 3.7volts, but some literature says not too discharge them below 2.5~3volts.
Do you ever run into problems with yours? Do you have a cut off system? If I got some of these, would I need any special equipment to protect the batts?
Also, here are some other sites that sell these little buggers;
Bob Selman Designs “users.joplin.com/nbselman”
FMA Direct
Skyborn Electronics “bktsi.com”
I’ve only checked the first 2. The last one I couldn’t access for some reason.
