Re: Different 2.4V Mod
#14694
Theoretically:
When you apply double the voltage across the same resistance, it takes twice the amount of current I=V/R. This means that when you double the voltage to the bit motor or steering coils (these are both resistance constants)it takes twice the current which means if the original battery was 50mah you would need a 100mah battery of double voltage to run the same amount of time. I would expect shorter then stock run times with a 80mah 2.4V battery then a 50mah 1.2V battery.
Again, this is theoretical. I’m interested in actual data
