Re: Different 2.4V Mod
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Different 2.4V Mod › Re: Different 2.4V Mod
Hey
Well i made my own charger, using the way by the ones made by K.I.T.T and the guysat http://www.questformadness.com/
It included buying a 4 AA battery case from jaycar (http://jaycarstore.webfactory.com.au/index02.ws4d– Product ID PH9200)
Using the instructions at QFM i took apart one of my Bit char-g controllers and unsoldered the charging component and then soldered those wires to the Battery case.
I put 4 AA batteries in the battery case (giving it 6V of charge) and put my bit char-g (with the 3.6V battery in it) on it and charged it for a minute… and it FLEW, wheelies heaven !! Although the charge only lasted about a minute, i then put it on for about 3 mins and got about 2 mins of run time
More tests still need to be done, the low run time could be due to the battery, as i have been stuffing around with it trying to charge it on the normal charger, etc. I have a new battery so i will chuck that in there, charge it up and let you guys know what the results are
Again if anyone has found any other batteries that will fit in the cars aswell as the one im using (3.6V, 43MAH from jaycar – SB1606) please let us all know, especially if we can find a battery that has better run times with the same performance .. hehe
Well if anyone has anything to say about these battery mods, lets hear it !
