Re: Does anyone have a voltmeter?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Does anyone have a voltmeter? › Re: Does anyone have a voltmeter?
There are two voltage points, similar to non-booster cars. The low point is always about 1.3V and the high point is 3.0V in boosted state and 2.7V in non-boosted state. That’s not all, however. In non-boosted state it’s not a constantvoltage. Although the voltmeter shows it a constant, if you connect an LED to the contact in non-boosted state, it will flicker. Which kind of sucks. You should be able to see it with an oscilator but I don’t have one. I also took the measurments of the voltage going to the motor. I’m not sure that this is correct but it seems to be 1.3V for boosted and 0.7V for non-boosted. However, I’m not sure about these two measurements.
