Re: Does anyone have a voltmeter?
#14126
THANK YOU XSRACER!
What do you mean by 2 voltage points? Where are you measuring? At the transistors?
When you tested voltage at motor was the motor out of the car and you tested the terminals or was the motor and wheels hooked up and spinning as you tested voltage?
I guess your LED trick proves that the motors are pulse controled instead of voltage controled.
-Peter
