Re: enertec bit clones, $16 aud!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › enertec bit clones, $16 aud! › Re: enertec bit clones, $16 aud!
December 15, 2003 at 4:15 am
#38826
remove the screw that holds the pcb down and CAREFULLY lift the pcb. enertecs are not wired up as neatlty as a bcg and there’s a bit of tape holding the batts down which has steering wires stuck to it so go easy. you’ll see what i mean. once you’ve done that you’ll notice there’s 2 screws in the motor cover. take ’em out and with a small screwdriver pop the cover off through the tab slot behind the motor.:8ball:
