Re: Front Springs
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Front Springs › Re: Front Springs
May 23, 2002 at 5:37 pm
#13976
There two different springs being discussed. One is the return spring for the steering, which is being sold my toyeast. The other springs, which this thread is about, are used for the suspension to give more of a true action, instead of using the stock sway bar. Since you can cut them to different lenghts you could also make your own adjustable suspension.
