Re: GURU PRABBIT about DUAL MOTORS
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › GURU PRABBIT about DUAL MOTORS › Re: GURU PRABBIT about DUAL MOTORS
cool. i got 3 extra old style motorola pagers from work.
hey prabbit, how does this sound. use a digi q for a forward/back/up/down moving helicopter.
the digi controls 2 motors seperately. both spin at the same rate when the controller wheel is not turned. this could control the up/down movement.
if you connect theleft side motor to the front andright side motor to the rear, then when you give throttle, the heli will lift evenly, but when you add in turning the wheel to the left/back, the heli’s rear will get higher than the front(or the front will drop lower than the rear), gotta see exactly how this works. so when i turn the wheel to the right/front, the heli’s front will effectively get higher because the left/rear motor wil be spinning faster than the right/rear motor.
this is all on a 2 evenly sized top rotor heli like the military transport ones.
tell me if this is worth trashing my digi-q for if no one buys it. b
