Re: GURU PRABBIT about DUAL MOTORS
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › GURU PRABBIT about DUAL MOTORS › Re: GURU PRABBIT about DUAL MOTORS
Ideas should never be trashed, just revised sometimes.
2 rotor heli sounds great. The rotors will have to be turning opposite directions to keep the heli from spinning around in flight (same reason for having thetail rotoraimed sidewayson a single rotor plane)which is perfect since the motors in the digi spin oposite directions for left and right. And your right again, it will tilt forward and backward with left and right movement of the steering. I have a feeling it will spin (turn)one direction when going forward and another direction when backward since the opposite spinnig rotors won’t exactly counteract eachothers torque. Just like changing the pitch on the tail rotor of a single blade heli.
Sounds like good idea, I think the next challange will be making it light enough to get off the ground with such little horse power.
-Peter
