Re: GURU PRABBIT about DUAL MOTORS
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › GURU PRABBIT about DUAL MOTORS › Re: GURU PRABBIT about DUAL MOTORS
man, check this out.
http://www.planetinternet.be/pixel/
a 4 oz helicopter. yes, the chick is real. (chick as in chicken, not female 🙁 )
actually a heli is hard if one was to do it correctly. a pseudo one is possible where the rotor does not tilt. maybe one rotor to lift and another on the tail almost parallel to the ground + slightly tilting forward which you would turn on to tilt the copter forward and then the main rotor would pull it forward. unless you use the steering mechanism (bit char) to pull/shift weights/coils closer from front or back to make the copter tilt. of course the hardest part is making the damn rotors that would create enough lift. oh well. we can dream right? b
