I’m using a NiMH battery (neither bit nor bullet). I don’t have pics of Cat-5 antenna mod but it’s easy. Take some construction grade cat-5 wire (should me solid copper core, not stranded) and use 1 wire a little longer then your current antenna. Unsolder your antenna and solder the Cat-5 on. It improved my range by quite a bit.
-Peter
