Re: How to use aluminum wheel sets?
#15155
I almost forgot, you must glue the covers on too, remeber, very little glue. Try pushing the covers in with the Eraser head of a pencil. (new)
Finally, for the front tires, you should make the holes on the wheels big enough to fit the original pin, althoug you are going to need to clip it a little, as it is it is too large and it will prevent the wheel from turning properly due to it portruding on the inside of the car, clip off a little bit only.
If you ruin the pins, you can get replacements at http://www.toyeast.com or just rebulid it using a small nail and some glue. Its difficult, but it can be done I will later post some pictures of my nephews car. We rebulit one of the front pins becuase itbent in the process of being removed and the broke when we tried to strighten it. Howver the car runs perrfectly, and the difference is not noticeble since the nail head sits behind the wheel cover.
