Re: LED mod plans?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › LED mod plans? › Re: LED mod plans?
August 2, 2002 at 9:28 pm
#14982
Limca, it’s pretty easy to determine where the wires go. They are all labeled on the circuit board. F=forward B=backward L=left R=right. These are all – outputs. The one labeled + is the common positive lead. I tried this with blue leds and it stuttered a little bit. I havent tried it with the dual cell mod and blue leds yet.
Rosin Core Solder Fumes … mmm mmm good.
I’ve soldered on all types of batteries even little lithium button cells. The key is high wattage hot iron, lots of flux and do it FAST. If it doesn’t take right away, let it cool and try again. Otherwise, well … you know, KABOOOOM.
