Re: mhz on oem bit-charg
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › mhz on oem bit-charg › Re: mhz on oem bit-charg
August 2, 2002 at 6:34 pm
#14972
what’s the difference between the mhz?
It’s so you can havemultiple cars running at the same time. Two cars operating on 27 MHz wouldn’t work because you’d be controlling each others car.
Also is it possible to get your rear wheels spinning hard enough to like do a burnout?
Not unless you do some of the high-power mods. Read the forum for more.
