Re: Mini Dyno
#14291
PRabbit is right about the factors affecting the theoretical RPMs.
The stated purpose for Questformadness.com’s RPM Equivalency Table is to help provide amoreeasily quantifiableunderstanding of the theoretical gains/losses with diff motor/gear combos. The resistance factorsPRabbit refers to that adversely affect RPM, are constant if the only factors you change are the motor/gear combos. Therefore the theoretical gains/losses depicted in the RPM table are unaffected. Simply put, applying the same resistance to the all RPM results, will just yield lower RPMs in the same proportions. So the information about theoretical gains/losses is still accurate. Hope this helps clear up how to read the table.
Also, converting the end-value RPMs to speed, whether scaleor actual,is still theoretical, because as mentionedearlier by Deejay40,this table does not take into account torque or resistance issues. So sorry if I got your hopes up guys, but your BIts arent THAT fast! hehe. J/K 🙂
