Re: Monster questions !!!!
#18980
rcs2die4
Thanks for the reply !!
I assume you meant the IW 04 TX gives you brakes an not the FireLap TX !!!
The no brake thing is cool asafterI have hopped the rest of the truck up will more
then likely buy a true kyosho board for it anyway…. With my mars EX-1 TXI can simulate
ABS braking anywaywhich is howI have setup my MR01.I do this by turning the end point for
reverse down to a point where it only just reverses, thenIsetupthe ABS function so it pulses
the reverse in little quick blerts which make the car slow down without goinginto reverse
andalso so it doesn’t lock thewheels upeither… I alsoassign the ABSto a button so I can
