Re: pix of my BitchG
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › pix of my BitchG › Re: pix of my BitchG
Dirk_Gent: Actually, i used supplies at hand. I filled in the rear deck with a hot glue gun. I gooped it in, used a heated Xacto blade to slice as much excess as possible. Sprayed w/ some primer I had for my real car. and painted it. The leather interior, leather convertible top envelope, and Leather bra is made of….Black electrical tape!! hehehe…
Floydski: But of course! and a cool place to hostonline images without ugly banners or restrictions. Mac.com just rocks my socks!
David: The front end of the chasis has a tab. the front end of the body has a slot. What i did was take a hot knife, cut a similar slot above the existing one. You will probably cut thru the body, but I just patch it with a dab of putty. You can do the same w/ the rear end but you will find that there isn’t enough tire clearance.
