Re: question on range…
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › question on range… › Re: question on range…
July 30, 2002 at 12:56 am
#14783
yeah my friend suggested that I stick 4 x AA batteries on the controller with a potentiometer across the added 2 batteries to tweak the voltage input to see if the range can be hiked up. As it is, my OEM controller has a much bigger range as standard than the 4 channel booster controller….gutted that is the case, but I’m using it mush more because of it.
But I will try getting a long extending antenna first to see if that improves things.
