Re: Question About Mini-Z AWD w/ LiIon
#61995
Well I sorry to say the heat problem on the V2.2 is from your Lithium Ion
batteries because of the AMPs that can push to the motor. You will have the same heat problem on the V4 Spider or the Bug. You are not going to get away form the heat problem. The thing I done in the pass is cut out the side windows of the chassis to let more air to cool down things. I reading about the V4.0 or bug they can take up to 12 volts but the other things like steering motor will not.
Regards,
