Re: rc tank questions
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › rc tank questions › Re: rc tank questions
November 6, 2003 at 11:53 pm
#47765
cool, thanks trash, that helps me out. i found a cheap 2 ch rc toy today with 2 vertical levers on the tx. i pulled the guts out, and the motors from the toy fit in the gearbox.works better than i expected! if i want to use the tamiya motors that came with the gearbox, should i wire them up exactly the same as the motors from the toy? the toy motors had capacitors across the terminals and also one terminal was wired to the motor shell. is this what you meant by your last sentence?:8ball:
Edited by – betty.k on 10 December 2003 03:15:21
