Re: steering too sharp
#13973
Actually, it sounds perfectly normal. My car did the same thing. You just need to learn to drive :smiley2: Seriously though, you need to learn to anticipate your turns and drive accordingly. One technique is to tap or pulse the turn button to smooth out your turns.
As for tires…unless you buy the AE86 Trueno Tune-up set, you’re not going to find anything softer than the tires you have until August (that’s when the Bit Char-G tire set comes out). However, if you get the Bit Racer tire set, you can put harder tires on the front. That will decrease the initial grip when you turn and make the front tires slide a little through the turn. Then your car will not whip around as fast.
