Re: SuperSlicks CAN be FET modded *UPDATE*
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › SuperSlicks CAN be FET modded *UPDATE* › Re: SuperSlicks CAN be FET modded *UPDATE*
UPDATE: If you look at the first pic in this thread, (top side), in the red circle, the transistor on the left needs to be replaced with an N channel, and the one underneath connected to the same motor wire/trace can be replaced with a P channel… I haven’t tried this yet though, I just assumed that since the tranny on the left had a black wire traced to it’s source pin, then it can be swapped for an N channel FET, and the one right underneath that transistor (connected to the same motor wire as that stock tranny) is a P channel…just a theory for now, I have yet to test these little babies….
Edited by – Charlie Brown on 29 August 2004 06:54:25
