Re: Tinting Windows
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Tinting Windows › Re: Tinting Windows
July 25, 2002 at 10:32 pm
#14696
I got this stuff made for blacking out car tail lights. It’s a spray can called auto shades. It worked pretty well. I’ve also used smoke x-19 on regular sizedr/c carslike derek. It also worked well. Just spray it on the inside of the shell and you’re done.
I would not recomend using tint film as it attracts static electricity and you could shock your car’s electronics. Also, it probably won’t stick toplastic very well and won’t look very good from the outside. Just a guess???
I haven’t tried the magic marker trick, I think I might try that next time.
