Re: what is the best gear/motor combo?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › what is the best gear/motor combo? › Re: what is the best gear/motor combo?
May 24, 2002 at 8:17 am
#14068
Try S-01 green 3.43:1 gear, or the red 3.95:1 gear. I found that 2.2 motors still have enough torque to push the S-01 gears, and the ratio boosts the top speed a bit. The GS-03 gears work better withMotorola / 2.6 / 3.0 / 3.8 motors. If you use the S-01 gearings, the take off is incredibly weak.
My absolute best gear/motor combo is a 3.8 w/a 12:1 gearing modified with the smaller front diameterrims/tires. The takeoff is always quick (w/hard tires it always peels out!).
Id love to hear what other combos anyone else has found very good.
deejay40
