Re: Wheels on OEMs
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Wheels on OEMs › Re: Wheels on OEMs
Barrell, The OEM front wheels will fit the Bit-Charg. The Bit charge frontaxle is a little bit hard to get out. I think Derek posted my procedure on how to pound out the axle somewhere in the tech section. If you can’t find it let me know. DO NOT TRY TO PULL THE AXLE OUT WITH PLIERS! You will bend the wheel and maybe even bend the axle. Press the axle out from behind so you don’t damage anything and take your old wheels off. Then press out the axle on the OEM. The OEM axles come out easy because they don’t have any barbs holding them in. I recommend using the Bit Char-g axles if you haven’t bent them but you can get away with using the OEM axles on your Bit Charg if you have to. The bit axle can only press in so far but the OEM axle can press in too far as to not allow the wheel to spin freely so you may have to back it out if this happens.
DOWNSIDE TO OEM WHEELS — You may be limited to only using the tires (that’s rightAuse’s, it’s spelled tires in the US not tyres)that come with the OEM. The OEM wheels are cheaply made and the ridge around the middle of the wheel that holds the tire in place is not verry accurate, It’s rounded off instead of nice and square. They make the tires for the OEM’s with a wider groove inside so the tire will fit. If you put soft bit tires on the OEM they’ll work but the hard tires don’t. The outer edges of the tires stick up and the middle of the tire is concave. There is a fix to this if you have a drill and a dremel. Chuck the wheel in the drill sticking out half way. This is the hardest part since the wheel is small and you don’t have much to chuck on. Now have a friend hold the drill solid on the table and spin the drill. You, with a dremel and a cut off wheel, cut the middle raised ledge nice and straight up and down. Do that to both sides of the ridge and then to the top of the ledge also. Now your Bit tires should fit.
A lot of work, yes. I would probably choose to buy a new Bit Char-g and use your old one for spare parts. The only reason I did this mod was because I bent a wheel and had an OEM for partsand didn’t have a Bit for parts so desperate times called for desperate measures. :smiley2:
Sorry for the lengthy babble, hope it helps.
-Peter
