Re: Working Pitlanes
#14720
Cool track…but where are the pits going to be?
Anyway, the working pit idea is pretty good. I thought Ifound a potential problem…I was wrong :smiley9:. But here’s a possible upgrade idea. Maybe have a “gate” to stop the car in the proper position (similar to the signs used in real pits to tell the driver when to stop). Once the car is stopped and charging,the gatecan then drop down or lift up to allow the car to go when it’s done charging. Anotheridea I had was to have the charging base lift up under the car. That way it would look like the car is being jacked up (like real cars changing tires). You also wouldn’t need to have the contacts spring loaded with that design.
