Droop, Weight transfer, Ride Height !?
Home › Forums › 1/8, 1/10, 1/12, 1/18 – Discussion › Droop, Weight transfer, Ride Height !?
- This topic has 4 replies, 3 voices, and was last updated 20 years, 7 months ago by
peteWah.
April 13, 2005 at 1:37 pm #12610
I m confused on the droop screw scenario and was wondering whether anyone can shed some light on this topic.
From reading various web pages on the topic, people use them to lower the ride height of the chassis (which is what I ve done), whereas other people suggest not to use them to lower the ride height but to use the springs and the threaded shock preloads instead and that the droop is there for distributing weight transfer – (I m not sure how it would do this though, as the droop screw restricts wheel arm movement).
Other web articles also suggest that the droop screw is used to protect your shocks from over extending and blowing out the base of the shock.
I ve now made some adjustments on by touring car so that when the car sits on a level surface, that the shocks/springs support the car and the droop screws do not touch the chassis at all until the car lifts off the ground… hopefully this is the proper way… and the front and back of the chasis is level to the ground with about 6mm clearance.
Can anyone explain how it s suppose to work ? Or is it in the too hard basket and I should go buy the xxx main chassis setup guide.
Thanks.
April 13, 2005 at 5:21 pm #59277
you got it about right kev… the droop is used to limit the amount of up travel b4 the wheels lift. on bumpy tracks use more droop, on smooth tracks use less droop. droop also affects the ballance of the car. there is a lot more to it than that but it even gives me a headache sometimes. best to experiment if you want but dont give it too much thought yet, sounds like you have it pretty right for now.
April 15, 2005 at 3:06 pm #59305Quote:you got it about right kev… the droop is used to limit the amount of up travel b4 the wheels lift. on bumpy tracks use more droop, on smooth tracks use less droop. droop also affects the ballance of the car. there is a lot more to it than that but it even gives me a headache sometimes. best to experiment if you want but dont give it too much thought yet, sounds like you have it pretty right for now.
Hey Big Dave, thanks for the reply – I understand it a bit better now… and will experiment with a few settings.
Hmm… limiting the upward travel would affect the weight transfer from front to back and back to front with diving and squatting.
Thanks !
April 15, 2005 at 3:50 pm #59306
thats it…i really dont like to play with it too much, but need to experiment more for different tracks.
BIG DAVE
April 15, 2005 at 4:50 pm #59307
To each his own setup…:smiley2:
