Mini-Z Parts Weights!
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Mini-Z Parts Weights!
- This topic has 10 replies, 3 voices, and was last updated 19 years, 4 months ago by
Ogier.
July 16, 2006 at 1:34 am #9687
Several months ago I acquired a set of jewelery scales capacble of accurately measuring down to 0.01g.
Since then I’ve been dropping parts onto the scales when I get a chance and comparing weights. So far we’ve only measured stuff on the NanoDragon and the AWD, but already the results have been interesting.
The Results:
- MA010 Centre Driveshaft
Stock Kyosho: 1.18g
Carbon Fiber: 0.34g
Kyosho Titanium (includes metal pinion): 1.31g
TopCad Alloy (includes metal pinion): 0.70g - MA010 Universal shaft (each)
Stock Kyosho: 0.47g
Kyosho Alloy: 1.14g - MA010 Knuckle/Hub
Stock Kyosho: 0.48g
PN Racing 0.5 Alloy: 1.06g - MA010 Differential
Stock Kyosho with PN Racing Alloy Outdrives: 2.18g
TopCad Alloy Ball Diff: 3.55g - MA010 Top Cover Front
Stock Kyosho: 1.34g
PN Racing Alloy (open top): 2.29g - Generic: Wheel Nut (each)
Stock Plastic: 0.04g
Alloy: 0.06g
Site Owner Guy. - MA010 Centre Driveshaft
July 16, 2006 at 1:36 am #27172
As you can see the majority of hop-ups tested so far are heavier than the stock parts. However this doesn’t take into account the improved rgidity, strength, durability and precision of hop-ups.
July 16, 2006 at 1:36 am #27474
July 16, 2006 at 11:18 am #27173
That is interesting, any chance for more comparisons? 🙂
I compared some 1 2 and 3 degree toe-in steering arms for an MR01 and measured 0.05mm difference between the 2 & 3 degree arms. I couldn’t tell them apart by eye checked their length with a micrometer.
Once installed, the difference in toe-in was visible.
So even if there’s “just 1 gram” difference, it might just be having a big impact somewhere 🙂
Weight wise, I imagine they were very much the same as the original part since they are all plastic.
Cheers, Graham.
July 16, 2006 at 11:18 am #27475
Cheers, Graham.
July 16, 2006 at 12:04 pm #27158
Yep, there will be more comparisons as I get parts and stuff. I’ll also try to weight stock parts.
It’s going to be a long process to make an authorative list, but that’s the goal of this thread…
The tough thing is that while I’d like to weigh all the hop-ups we stock, noone likes buying opened packs. 🙂
July 16, 2006 at 12:04 pm #27460
July 18, 2006 at 12:27 am #27149
Added a couple more MA010 shaft options
July 18, 2006 at 12:27 am #27451
July 18, 2006 at 1:28 am #27150
Plastic vs. Alloy wheels would be a good thing to weight.
July 18, 2006 at 1:28 am #27452
