Painting
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Painting
- This topic has 31 replies, 14 voices, and was last updated 21 years, 11 months ago by
oxhadokenxo.
July 19, 2003 at 11:02 pm #11162
How do i paint my body and what paint do i use
thanks
July 21, 2003 at 5:51 pm #23340
Just don’t use the spray on tamiya paints because it bubbles and cracks on the surface of the shell – based on my experience. I’m thinking of hand painting mine now.
Kevsta
July 21, 2003 at 5:53 pm #23341
for solid colors use a air brush with some testers model paint. for doing stripes and studd just use testors paint makers then just spray a clear coat on it after
July 21, 2003 at 7:45 pm #23344
I actually use the spray on tamiya paints and have had no trouble with mine. I usually do about three fairly fine coats and I really like the final result. I have also experimented with car spray paint and found this good too, but again it must be applied in thin layers.
July 23, 2003 at 12:14 am #22921
sand back some of the existing paint with fine grade sand paper and then use a light coat of primer then no matter what pant you use it’s safe
August 28, 2003 at 4:33 pm #39394
This is probably gonna sound like a REALLY stupid question..but I have a clear body I’m doing nothing with (I hate plain clear bodies)and I was thinking of painting it..which side should I paint (lol). I had a friend with large r/c cars and he always painted the underside so the paint wouldn’t scratch off..but which side do you paint..
August 29, 2003 at 1:38 am #37713
I usually paint on the outside, but I have heard of people painting on the inside, I’m not sure which is better, but I usually paint on the outside.
August 29, 2003 at 8:28 am #37723
oxhadokenxo, paint the outside of the body. Make sure you include a base coat/primer coat as well. Tape up the windshield and other areas you do not want painted prior to starting. If you are worried about the paint scratching off then add a clear gloss finish to your painted car.
If you want to have head and tail lights on your ride then paint those on the inside. For head and tail lights I would suggest a thin layer of paint only to glaze over the area. There are other ways/paints to do this but this has worked for me:)
August 29, 2003 at 1:41 pm #37736
Can someone tell me what kind of primer I need to use? Is primer neccessary? I don’t have a airbrush or anything so it’s not gonna be a pro job or anything, I just have 2 clear bodies and I dislike clear bodies…I guess I would be painting with a brush too and doing little detail with paint pens. So would primer be neccessary for something like that?
August 29, 2003 at 1:49 pm #39325
I dont use primer on clear bodies, I think you need to on the already painted ones. Just give it a very very light sand and there shouldn’t be any problems. Dont rely on me though, wait for someone more experienced to confirm.
August 29, 2003 at 2:27 pm #37297
From my model making experiacnce primer is not neccesary but gives better colour and I think it protects the paint job a bit more. but like barto I’m no expert
August 29, 2003 at 4:21 pm #37301
I’m guessing use the finest sandpaper possible? Anyone ever used spray paint?
August 29, 2003 at 5:47 pm #36730
your guess is right. DONT use real car spray paint. it is way to thick. and make sure you mask the windows and press real firm on the edges of the tape to stop piant messing up your windows.
good luck, and check the older threads about the topic……
August 29, 2003 at 6:58 pm #36739
Major tips that no one else has mentioned…
1) use only GOOD masking tape. Get the Tamiya yellow stuff or the BLUE tape that 3M sells.
All the other $2 beige stuff… don’t waste your
time and efforts.2) primer is good if you’re painting light colors
that are not very opaque. Primer gives opacity
to the lighter colours, covers up any darker
or clear areas.3) always use same type/brand of primer as paint.
4) if you don’t care for clear windows and can’t
be bothered masking, just paint the bodycolor
whole then handpaint the glass areas with black.5) BCG clear bodies are too thick for painting on
the inside. It’ll look like a lump of crystal… -
August 29, 2003 at 8:03 pm #36559
I do use spray paint, and yes the finest sand paper possible. z-beam, I believe you can use real car spray paint if you are very careful, the gloria in my gallery was painted using car spray paint, but of course, I shook it for about 10 minutes and made light coats.
September 1, 2003 at 4:07 pm #36239
10 minutes! that musta been my problem.
nice metalic purple. -
September 1, 2003 at 9:19 pm #35735
nah it wasn’t really 10 minutes, but a few minutes. I just painted my supra with car paint also, check it out here. I think it turned out well. just scroll down this page a little, both of my cars are there.http://www.bitpimps.lixlink.com/pages/phpForum/viewtopic.php?t=1510&start=135
September 1, 2003 at 9:19 pm #36037
September 1, 2003 at 11:03 pm #35711
I’ve used car paints like barto as well with no probs. Heat the can in *warm* water for about 10 mintues then shake the can for a futher 2-3 minutes. This works well……
September 1, 2003 at 11:03 pm #36013
September 1, 2003 at 11:15 pm #35712
oh ok, havn’t tried heating the can, thanks for the tip.
September 1, 2003 at 11:15 pm #36014
September 4, 2003 at 7:33 am #35548
September 4, 2003 at 7:33 am #35845
November 20, 2003 at 12:43 am #22689
what about using citadel model paint for warhammer would that work
November 20, 2003 at 3:58 am #22669
That’s a lot of surface area to cover if you are planning on inking and dry brushing a whole BCG cover. If done well the effect would look very good.
Anyway you get a better finish with spray on paint.
November 20, 2003 at 11:12 am #22513
With a bit more practice under my belt I would suggest that either airbrushing or spraying the primary color on you car is the best way to go.
Panda is right on the money with not mixing acrylic and enamel paints :blush: When you spray enamel ontop of acrylic it tends to bubble or strip the acrylic layer (I found that you can hand paint acrylic ontop of enamel with good results-but it is best to keep it simple and not mix). I also agree that primer should be used when painting light colors as you will have to spray on more layers of paint on without using a primer. And last… ph2t and others are right on the money when they tell you to warm the paint (and shake it) as it will give you MUCH better results. Just don’t shake the airbrush propellant:)
As for sanding prior to painting I feel that for me it only helped on previously painted cars (helped take off a layer or two of paint so the final job doesn’t look so thick). On clear bodies I just make sure the body is clean. But I am open to other ideas on this one.
sorry for the long post and thanks Panda, should have listened to you earlier:smiley2:
November 20, 2003 at 5:38 pm #22539
painting is fairly simple. ive never done a bit, but my 1/24th kits usually turn out brilliant. tamiya paints are good but make sure you buy the correct type. get plastic paints, not the lexan body paint. ALWAYS USE PRIMER. i dont heat my paint, i just shake it for 5minutes or so and make sure its nice and ready. clear gloss works well, but you need to shake that ALOT so it doesnt come out gluggy. also for that showroom shine use some of tamiyas polishing wax, its the best thing on earth to cut back that rough paint job into a silky smooth mirror finish.
*was not paid for that advertisement :clown:*
November 20, 2003 at 5:58 pm #22526
Haven’t tried the wax. Will have to look for it next time I am in a hobby shop.
November 23, 2003 at 12:57 am #22558
i used car paint on skyline shook it for bout 3 mins they just sprayed over it, taping it first but, i never use primer. The body was white so there aint really a differnce when using primer or not.
January 3, 2004 at 6:31 am #38129
peedee: if you can dry brush well do it, i have and it looks great if done subtly. clear coat afterward to protect the art…
‘prezza: masking sux bad, so painting windows with acrylic silver or black after a nice enamel spray like you said is my prefered technique. but just as before give it a clear coat afterward for nice shiny looks.
another tip for sprayers: tamiya coloured transparent gloss’ are an awesome creator of realistic depth. a metalic purple with blue transparent (2 coats) gives the deepest bleu you ever seen. candy green metalic ala my echo (or whatever) with blue on top results in a real nice jade green.
soon to see what the metallic purple with a pink transparent will result in.
January 3, 2004 at 8:26 am #38126
brendan, primer will definately help when you are putting lights in your body or are working with a body mod or the body is several different colors when you start.
