will thease fit
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › will thease fit
- This topic has 11 replies, 4 voices, and was last updated 17 years, 8 months ago by
jimmy.
February 16, 2008 at 10:58 am #12914
help will the ausmircro 2mm weel nuts fit in the nut wrench or will i need that white attement:huh:
February 18, 2008 at 4:24 am #61704
the alloy wheel nuts stripped my plastic nut wrench 🙁
im oblivious to the ‘white attachment’ but id recommend it as I had a few dilemmas.
I cant even tighten them to the point that they dont move around.
February 19, 2008 at 7:48 am #61708
they will fit no problems just be gentel when putting them on. but its worth it if you have new wheels esp if you use alloy wheels.
February 20, 2008 at 5:32 am #61709
shouls i oil the nut and axle treds befor puting then on
February 20, 2008 at 7:08 am #61710
never found a need to do so. just be careful putting them on as they are on the same side.
February 21, 2008 at 6:14 am #61712
what do u mean the same side
February 21, 2008 at 7:19 am #61713
sorry was having a brain fadeeeeeeeeeeeeeeee when i was typing i mean on the SMALL side.
sorry.
whoops
February 21, 2008 at 7:24 am #61714
so are the wheel nuts 5.5 mm diamiter
March 4, 2008 at 11:26 pm #61677
😡 they dont fit got them yesterday :angry: does any one know how to make them fit
March 5, 2008 at 12:12 am #61678
by the way i have mr-01 does that make a difference
March 5, 2008 at 2:46 am #61681
I have the ausmicro alloy wheel nuts on my mr01, mr02.
I use a 4.5mm nut wrench from a precision screw driver set that I bought from an electronic store.
The plastic wrenches that come with the kit pretty much suck shiet.
March 24, 2008 at 12:15 am #61495
this is a message for talldude are there any mini-z tracks in darwin
i use tweesers to put them on now
