Re: aluminum heatsinks?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › aluminum heatsinks? › Re: aluminum heatsinks?
May 9, 2003 at 5:54 pm
#31698
well the idea is that metal transfers heat very quicky and the bigger surface area it has to get rid of the heat the quicker it will cool down
as to if it really works on a bitcharg is a big question because most likey does get that hot allthoght is does weight more than the aluminiom one so the 0.1 gram or so might make a sighlt diffrence but it probley better to give the money to charity
________________________________________________________
Bit Char-G 57mhz Booster Fairlady Z
MINI Z Wrx WRC 2000 This thing RIPS
