Re: charging from dc adaptor
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › charging from dc adaptor › Re: charging from dc adaptor
December 24, 2003 at 12:34 am
#48951
No. I’m using a fet modded 2-speed bit pcb.
I talked to an electronics guru today and he said it’s probably the gauge wire I’m using. I use some pretty thin wire that normally works well with the dual cells, but may not have the capability to keep up with the higher voltage and current from the charging system for the quad cells. I’ll swap all that stuff out tonight and get with you guys when it’s done.
