Re: Extended charging times on your controller
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Extended charging times on your controller › Re: Extended charging times on your controller
ok i must of gotten ripped off at dickies i spent like 30cents each on a cap!! hahahahahaha
i tried the mod 2nite with a little help from a mate and we put the new cap on my lxx 27mz booster controller and it charges the car for 15secs more….
when i change the cap i noticed that the orginal lxx cap was a 10volt 100uf capitor and the new 1 i put in is a 16v 100uf one.
still the car ran for longer on that single charge so all around its a success.
also my h-1 27mhz hummer doesnt charge no more i checked to see the cap in it and i found two caps in it one 10v 33uf and 1 10v 220uf could these be blown cauing it not to charge anymore? would i stuff the controller if i put in two 16v 100uf’s to replace them both??????
also (again) when i was buying the caps i saw they had 25v 100uf’s which were the same size, would these be better to extend chargiong times or would a higher uf rating be better?
