Re: i’m flying!
Home › Forums › Floating & Flying – Discussion › i’m flying! › Re: i’m flying!
#27436
merc-blue
ill try to find somthing, by drifting i mean rotational drifitng. it will control the offset speeds of the 2 rotors as you increase the throttle the amoutn of offset needs to change to keep it facing in one direction, want a simple explination, turn the pot all the way in and slowly throttle up then turn the pot all the way out and slowly throttle up you will see its affect, when its in the right possition you should be able to throttle form 0-100% without the nose wavering (side to side or fwd/back drifting is done with COGs and trims. pity the head doesnt come off cause balancing them and getting blade COGs right would really help these models
