Re: i’m flying!
Home › Forums › Floating & Flying – Discussion › i’m flying! › Re: i’m flying!
#27740
merc-blue
Trent,
when the gyro is setting it self you should leave it to center and dont move it while its centering.
the “?????” trim pot is your gyro rate so bassicaly if it has a habit to drift around in a particular direction tweak the trim pot to stop it. being a yaw rate gyro you will never get it spot on and as your flight goes on it may warm up and start to drift again slightly
