Re: Kyosho Mini-Z all wheels drive
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Kyosho Mini-Z all wheels drive › Re: Kyosho Mini-Z all wheels drive
December 25, 2005 at 11:14 pm
#18021
installed the bearing set Aaron kindly sent me. who took an hour to install them? you took apart waaay to much of the car!
if installing bearings just remove the front and rear drive assemblies and pull the shaft out with pliers. the bushings can be swapped out for bearings without going any where near the fiddly pcb board location.
running sweet now. much smoother running ive noticed. i swapped the spacers for the front wheels to the bottome of the knuckle so it sits 1mm lower than standard.
