Re: Li-Po setups
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Li-Po setups › Re: Li-Po setups
November 2, 2006 at 9:39 am
#25432
well if it’s definately a drive fet (or both) you can buy the upgrade fets at the shop and replace them. i’d recommend doing a double or triple stack.
whenever you do a drastic upgrade like lithium cells you need to monitor things like fet and motor temp at first in order to avoid these sorts of disasters. :8ball:
