Re: Li-poly batteries in a bit/pht2 or ma please look
#52814
HACHI-RYOKU
I would say no. But honestly, I wouldn’t know. ALTHOUGH, you can charge li-poly batts at C100, witch means the fastest current you would want to use is equal to the mah. I.E. 80mah batts would use around 80ma to charge and that would take about an hour. So, if you have two 80mah wired in parallel, that would be 160mah. You could test it to see how long it would take to charge. If it takes 2 hours at 80ma to charge, than you know you can double the current.
I would like to know how it goes. Let us know.
