Re: TX2C/RX2C Channel Question
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › TX2C/RX2C Channel Question › Re: TX2C/RX2C Channel Question
Thank you for the quick reply. The link you posted gives me the answer I have been looking for. The RX6/TX6 chip seems to have two extra channels I can use to drive a servo. I don’t know if you have personally used a car with the RX6/TX6 chip but if you could direct me to an online store that sells them I would appreciate it. The closest I could find was: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=44025&item=5904389527&rd=1&ssPageName=WD1V
It is the same seller PH2T bought his off of but it is on Ebay and the guy’s english is less than perfect. :dead: Are these the right cars? Also, do you know what frequency they run at? I’m in the U.S. and only 27mhz and 49mhz are legal…even though I know with the range on these things it doesn’t really make a difference I’d still like to know, if you have the information.
Thanks,
-Lost Cause
