Charger
Viewing 3 reply threads
    • #12129
      merc-blue
      im sick and tired of charging my batterys off a car battery
      has anyone built a stepdown transformer or sumthign so i can charge from a 240V outlet?
    • #51258
      PandaBear
      Yes, you can use a bench powersupply like the ones
      you’ve used in the school sciencelab. You can buy
      them from Dick Smiths and electronics shops… ppl
      use them also for powering their CB Radios at home
      when its out of the car/bus/truck. These will
      supply 13.8V DC which is fine for chargers.
      You must use one with enough current capacity.
      eg If your charger can charge 5A, your PSU must
      be rated to pump out 6A or better (@ 50% duty).
      More headroom the better… but of course they get
      dearer and heavier as they get bigger. A good PSU
      is never cheap but lasts forever.
      Or you can buy a RC charger that runs off 240V.
      CDC makes a good one ($500), I use a Novak Ionic
      off 240V and there’s other cheap ones under $100 too.
    • #51268
      Avatar photoAaron
      Keymaster
      Yeah that Arlec brick is pretty good – apparently theeres a cheaper version of it around…..
      The brick won’t do NiMH though…..
      Site Owner Guy.
    • #51270
      PandaBear
      This one’s the Arlec AC/DC brick, 3A and nicad only:
      but this Ansmann AC/DC one does NiMH too for for ~$60:
      Novak’s NiMH2 charging routine is still the best imho. Used in Millennium Pro & Ionic, leaves the battery nicely warm everytime.
      Some other chargers have been reporting unreliable, some can overcharge your packs every now and again. (If a charger did that even just once, I’d not trust it ever again.)
