charging AAA s
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › charging AAA s
- This topic has 22 replies, 6 voices, and was last updated 21 years, 7 months ago by
merc-blue.
July 17, 2004 at 10:27 pm #12264
just wondering if you can charge AAA s with a normal 1:10 scale battery charger? and if so, at what charge rate(amps) should i charge at. i just went and spent like $30 on this charger for the AAA s and then thought to myself hmm i wonder if i can charge them with my other charger. should of thought of that b4. god i m stupid:dead:
July 17, 2004 at 11:11 pm #53654
yeh you can.. depends on the AH rating of the batterys i charge my .8 AH at 1.5-2 amps
July 17, 2004 at 11:16 pm #53655
wat u mean by AH rating. the batteries are 700mAH is that wat u mean?
July 18, 2004 at 1:10 pm #53660
yeh thats it.. milli (m) is the same as x10^-3.. so thats the same as .7 you can charge them on 1.5 amps
July 18, 2004 at 2:32 pm #53668
thanx, u smart
July 18, 2004 at 2:34 pm #53669
lol no maybe u are dumb.. JK.. what 1:10 u have (im guessing that what u use a delta peak for)
July 23, 2004 at 10:25 pm #53898
if you’ve bought a dedicated charger for aa/aaa batts then use it!
what type of batteries are they?
July 23, 2004 at 10:39 pm #53899
z-beam a delta peak is a much better charger than a ni-cad/nimh charger (if its a set for a time period then com back) unless its a delta peak which most arent
July 24, 2004 at 12:17 am #53903
anyone got that 45 min AAA `charger for $17.90 from dinball rc mart? If so, is it any good?
July 24, 2004 at 12:25 am #53905
17.90 USD + postage.. i would get a 2nd hand delta peak off ebay .. can do them in 15 mins (with a ice pack)
July 24, 2004 at 12:28 am #53906
hmms.. how do u know when the batteries are charged? and in what way do u use the ice pack?
July 24, 2004 at 12:36 am #53907
a delta peak cheack the output of the batterys and stops when there fully charged and then swaps to a trickle charge (to keep them charged fully untill you check) you can vary the input to your cells to vary charging times.. the ice pack its too keep the cells cool (because of high input) all the 45 min charger will be is a standard charger .. with a higher current (my cheapo charger does them in 5 hours with its output this thing wil have a higher output to charge them faster.. pretty simple the 45 mins thing is abit of a gimick i think.. you basically plug them in and do some math to work out a suggested charge time but never fully charged becasue you dont know about residual charge the worked charge time is always abit undercharged etc etc etc .. if you dont get that tell me and i will re phrase it all
July 24, 2004 at 12:40 am #53909
hehe well i dont really get it .. lols
but about delta chargers, they wont overcharge the AAA batts but since you supply more current they’ll heat up so therefore u use the icepack to keep em cool? and it’ll only take 15 mins that way?
How much current does the delta peak charger supply versus a standard charger?
July 24, 2004 at 12:48 am #53910
well a standard charger supplys a set current a delta peak can supply a varity of different currents set by a knob on the front mine does up to 10 amps (which will blow most standard batteys only high capacity batterys cna be cahrged).. u can do low current for battery condidtioning and high current for quick charging between races… a delta peack can have the batterys set in them “charging for a month” and not over charge try it with a standard charger (DSE sorta thing)and you will have a fire.. yeh 15 mins on a high curent
July 24, 2004 at 12:51 am #53911
hmms..
would this charger work for Nimh batts lols even tho it says Nicd? hehe.. and is this the type of charger im looking for?
I just hook it up to a AAA 4-cell holder and it’ll do its job?
July 24, 2004 at 12:58 am #53912
most chargers do both nicd/nimh (pretty much the same chargin sequence)
July 24, 2004 at 1:01 am #53913
This is how I charge my batteries.
Get a large cup of icy water, and a plastic polythene bag.
Put the batteries in the bag, and throw in the cup, make sure that the batteries don’t get wet.
This way you can charge the cells at 2+A without them overheating to self destruction.
The other alternative is Rayovac IC3’s
These are self delta peak charging cells that fully charge in 15 minutes…..i am yet to get any but i hear they are great.
July 24, 2004 at 1:04 am #53915
lol jamie i do mine at 4.5 amps and just sit forzen peas ontop and they dont heat up THAT much
July 24, 2004 at 1:05 am #53916
sorry when i said this charger.. i meant this:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=1200&item=5910375796&rd=1&ssPageName=WDVW
can it do nimh? and is this the sort of charger im after?
thanks
July 24, 2004 at 1:09 am #53918
yeh that will do it.. and yeh hook that up to a 4 AAA pack and you will do it you will beable to charge them like jamie said much faster then the rcmarts ones.. just a note (these all have 12V inputs) so you can use either a car battery/gel cell to power it or a 12v power supply with a current rating for a few amps
July 24, 2004 at 2:38 am #53923
From memory Ni-Cad batteries have a sharper voltage drop once they peak than Ni-MH batteries … so Ni-Cad Chargers may not notice that a NiMH battery has peaked because they arn’t looking for such a small voltage drop – consequently Ni-Cad chargers may overcharge (ruin) Ni-MH batteries.
July 24, 2004 at 2:58 am #53924
oh ok thnx i’ll look at getin one from america on ebay
July 24, 2004 at 12:40 pm #53928
yeh icebreaka look for a nicd/nimh delta peak
