charging problem with bit char-g
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › charging problem with bit char-g
- This topic has 9 replies, 4 voices, and was last updated 21 years, 8 months ago by
jamiekulhanek.
June 28, 2004 at 5:32 pm #10601
i’m hoping someone can help me…
my 40mhz bit won’t charge when put onto it’s controller. i’ve tried to charge it on a different controller and that works fine, so it’s a problem with the handset itself.
when the bit’s charged it can be operated perfectly with the (non-charging) controller, so it’s only a problem with the actual charging.
when i connect the car to the handset the charging led flashes once, then nothing. when the 2 contact points on the controller are touched to each other, the same.
so it recognises there’s a circuit, it just doesn’t seem to actually charge the bit.
batteries are new, etc.
if anyone has had this problem or knows about it, i’d be grateful.
-james
June 28, 2004 at 7:07 pm #32045
Have you tried holding/wriggling it down?? Perhaps a bad contact……
If that doesn’t work, it may be something more complicated……….
June 28, 2004 at 8:43 pm #32039
boy have i ever. pressing, wriggling, etc.
i (carefully) disassembled the controller last night to see it there was anything that had come loose or visibly broken, but nothing stood out.
how irksome!
June 29, 2004 at 1:55 am #32027
Do you own a digital Multi Meter???
June 29, 2004 at 3:01 am #32025
Might be a faulty component in there. You might just have to tolerate charging it on another controller and then running it with that one.
June 29, 2004 at 3:03 am #32024
i do, but i really wouldn’t know where to begin.
any ideas on what could be a likely area to start poking around with it?
if not, i guess i’ll just have to start from the start…
June 29, 2004 at 3:09 am #32008
never! that’d be too annoying.
i’m sure it can be fixed. oh, perhaps i should have mentioned that it used to work fine, just now it’s stopped. it wasn’t dropped or anything like that, so it’s strange…
in any case, i will see it fixed!
June 29, 2004 at 7:57 am #32002
Is it an LXX or super perfection?
June 29, 2004 at 4:34 pm #31991
it’s a standard australian compact char-g.
June 30, 2004 at 8:48 am #31964
I would recomend taking it back for another car or your money. I agree with MA. It’s something faulty, and would be most quickly fixed by replacing it.
