charging problem with bit char-g
Viewing 9 reply threads
    • #12221
      i m hoping someone can help me…
      my 40mhz bit won t charge when put onto it s controller. i ve tried to charge it on a different controller and that works fine, so it s a problem with the handset itself.
      when the bit s charged it can be operated perfectly with the (non-charging) controller, so it s only a problem with the actual charging.
      when i connect the car to the handset the charging led flashes once, then nothing. when the 2 contact points on the controller are touched to each other, the same.
      so it recognises there s a circuit, it just doesn t seem to actually charge the bit.
      batteries are new, etc.
      if anyone has had this problem or knows about it, i d be grateful.
      -james
    • #52917
      jamiekulhanek
      Have you tried holding/wriggling it down?? Perhaps a bad contact……
      If that doesn’t work, it may be something more complicated……….
    • #52923
      boy have i ever. pressing, wriggling, etc.
      i (carefully) disassembled the controller last night to see it there was anything that had come loose or visibly broken, but nothing stood out.
      how irksome!
    • #52944
      jamiekulhanek
      Do you own a digital Multi Meter???
    • #52952
      micro_Amps
      Might be a faulty component in there. You might just have to tolerate charging it on another controller and then running it with that one.
      :)uA
    • #52953
      i do, but i really wouldn’t know where to begin.
      any ideas on what could be a likely area to start poking around with it?
      if not, i guess i’ll just have to start from the start…
    • #52955
      never! that’d be too annoying.
      i’m sure it can be fixed. oh, perhaps i should have mentioned that it used to work fine, just now it’s stopped. it wasn’t dropped or anything like that, so it’s strange…
      in any case, i will see it fixed!
    • #52962
      HACHI-RYOKU
      Is it an LXX or super perfection?
    • #52981
      it’s a standard australian compact char-g.
    • #53007
      HACHI-RYOKU
      I would recomend taking it back for another car or your money. I agree with MA. It’s something faulty, and would be most quickly fixed by replacing it.
