Engine braking
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Engine braking
- This topic has 15 replies, 7 voices, and was last updated 23 years, 1 month ago by
micro_Amps.
January 15, 2003 at 8:20 pm #10062
Hi again,
Does it seem like the bcg stops really really fast when you let off of forward or reverse? I know that bits are really small and don’t have a lot of momentum, but doesn’t it seem like the wheels stop turning really quickly?
I was wondering if the motor was shorted when not pressing forward or reverse, which would make the motor stop really quickly…
Does anyone have schematics of the Bit electronics in the car so I can be sure?
January 16, 2003 at 3:55 am #43249
As far as I know the armature of the motor is not shorted when forward or reverse is let released. If it was the wheels would lock and skid when you let the button go. The reason I say this is I saw a mod on a site somewhere that puts ‘engine braking’ on when you let go. The reason it stops so quickly is because of the high gearing. I wouldnt worry about fitting the mod, I cant see it adding to handling, performance or enjoyment for that matter
uA -
January 16, 2003 at 4:00 am #43247
Isnt this supposed to be in the techo section :smiley2:
January 16, 2003 at 5:07 am #43235
When KIT racer gears are used, the braking performance is greatly reduced. The 12:1 BCG gears give the best braking.
January 16, 2003 at 1:26 pm #43225
hum..y do yall want quick breaking…i hate it..i want me to slow down nice and gently…does any1 kno how to do this?
January 16, 2003 at 5:38 pm #43209Quote:I was wondering if the motor was shorted when not pressing forward or reverse, which would make the motor stop really quickly…
The motor is definately not shorted.
A couple of my char-g’s free wheel a bit better than the other’s.
It can depend on how freely the gears rotate.http://www.users.bigpond.com/sandrashane/char-g/compact.html
January 16, 2003 at 6:18 pm #43207
It is fun though, cause its like doing a handbreak turn, if you have enough power!:smiley16:
Round and round not up and down
January 16, 2003 at 6:36 pm #43204Quote:The motor is definately not shorted.
It can depend on how freely the gears rotate.Oh, so I guess its just because my stock gear doesn’t free wheel very well…
Thanks!
January 16, 2003 at 6:40 pm #43203Quote:Isnt this supposed to be in the techo section :smiley2:
Oops… hehehhe:D
January 17, 2003 at 6:50 am #43132
the motor will create a back emf when its rolling tho…this creates abit of breaking power via eddy currents..
http://gtahh.web1000.com/
January 17, 2003 at 8:35 pm #43098
Back emf… hrmm…
Depending on the actual circuitry of the car… Rolling the car backwards for a very very looonng time when it is discharged could recharge the battery? 😀
Heheh, just kidding… :smiley2:
January 17, 2003 at 9:05 pm #43095
Sorry to rain on your parade but it wouldnt charge, because the drive transistors (even if turned on) wont conduct on reverse polarity.
If the motor was directly wired to the battery it would tho, but then you would have no start/stop control when the battery is full.
The back emf will only ‘brake’ the motor if it is shorted accross a resistance. When you let ‘forward’ go, the time that the motor takes to slow down really depends on what gear set you have in and how much friction is in the drive train.
Sorry, I just cant resist these techo issues:dead:
even if they are in the wrong section:shock: -
January 17, 2003 at 9:10 pm #43093Quote:Sorry to rain on your parade but it wouldnt charge, because the drive transistors (even if turned on) wont conduct on reverse polarity.
even if they are in the wrong section:shock:I know I know… I was just fooling…
hrmm… can the topic be moved to BCG Technical? Although I think its pretty dead now…
January 20, 2003 at 6:02 pm #42965
the standard bcg pinion gear has 6 spokes
a kit racers got 7
but my oem special ed.loctite zexel’s got 8 spokes
i’ve had to cut at my bcg’s so that any pinion can be used. i also use flat tipped screws to balance the angle of the motor. this is how to tune gears to be loose (no brakes) or tight (hand brake). can you buy the 8spoke special ed gear sets? -
January 20, 2003 at 6:17 pm #42963
Hmm, I think it could be because of the motor, i have a BCG with a 3.0 and a BCG with some crazy nano racer motor in it, when you stop with the 3.0 it instantly stops and with the nano racer it rolls for a little bit, even when stopping on a hill (on my track) the car rolls back.
Bap Bap Bap
January 22, 2003 at 6:33 pm #42763Quote:the standard bcg pinion gear has 6 spokes
a kit racers got 7
i’ve had to cut at my bcg’s so that any pinion can be used. i also use flat tipped screws to balance the angle of the motor. this is how to tune gears to be loose (no brakes) or tight (hand brake). can you buy the 8spoke special ed gear sets?Ehhh… I”m not really brave enough to do a lot of modding on my bit so I’m not even going to try and tune my gears like you’ve described. Haven’t even heard of 8 spoke gears…
On the other hand, I bought a KIT racer last night for the motor and batt. The 2.6 rolls after I release the gas, so I guess it just comes down to the characteristics of motor. And not due to a design thing.
